I saw a red Stagea this afternoon after work, it was parked right outside the JB Hi-Fi in Church Street in Parramatta. Number plates were STA-63-A.
I was gonna yell out the window, but the guy looked kinda busy with the driver's side rear door open, as if he was putting a seatbelt on a kid or something. By the time I'd turned around and found a spot, jumped out and walked down to where he was, he'd gone. I would have asked him if he knew about SAU, and/or if he was on here...
I could have taken his spot, too - wouldn't that have been the strangest co-incidence, a Stagea taking the parking spot of another Stagea.
my first stagea spot was yesterday at the corner of princes Hwy and Narre Warren Cranbourne Rd in Narren Warren VIC...
last place i thought i would see one but hey it was nice..
Marrone/red and from where i was (inside At work) seemed to have Wheels and i think a dayz spoiler and some skits but could be wrong
Edited by humble
hehe, i'm getting the opposite, my girl is trying to convince me to get a skyline again. she doesn't like the wagon much, well not for her to drive.
Not sure why - it's a pretty similiar drive! Why doesn't she like the wagon? It can't be size - there is only 10cm difference between my R34 and S2 stagea, can't be power - they both move pretty well, etc etc etc....
The main difference I notice is the turning circle of the stagea - it is noticeably larger - probably due to the front wheel drive limiting how much the front wheels can turn...
Ian
I've told her numerous times that's there's no size differnce, but that's the only argument she sticks with. i think it's an illusion with the back of the wagon, that's all.
Well turns out i'm getting my old R33 back for a bit now, my brother is heading overseas and leaving me with it to sell, than i'll have his mighty chaser to putt around in as well, should be fun
I occasionally see a white Stagea with white Rays G-Games rims on Mowbray Rd at Chatswood.
Very nice.
Hey, that's my new beast !
I'm glad you like it, it's been a while comming.
The only drawback is that it's an automatic.
Will post some pics soon. :)
Spotted a series 1 silver beast coming out of Shailer Park State School, bout 8:45am this morning. Looked stock except for these FAT side skirts with HUGE air scoop thingies that ran nearly the length underneath the rear door :)
I waved, but it was some older guy who gave me a wierd look, maybe because I was in a shirty old ford falcon EA.... oh the shame!
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
