spotted (by my dad) silver stagea came flying past him in his coach near sydney today had ACT plates he said.
its the only one he has seen on the road other than mine so he thought he should call me an lemme know ASAP. cos hes a bit of a car nerd too. just like the rest of us according to the petticoat parliament.
Hmm, thought that might have been me, but i was in bathurst then went to canberra yesterday. might be the other silver one in town.
Spotted, Series one white with no wing and rims around heidelberg and lower plenty a couple of times over the last week.
And a maroon s1 came through Heidelberg KFC today had what looked like days skirts? and a set of rims.
just before xmas i parked next to one at the pier st carpark in perth.
spotted another red one in rockingham the same as mine.
also, while crusing down south i spotted one in Denmark, the guy who runs the BP down there owns it.
Shaun
Spotted Bayside Blue S2 RS Four S (Ian?) on Monday 22nd, driving through Aireys Inlet on the Great Ocean Road, I was in my Black S1 turning left onto the road heading the other way...
wonder howmany stags there are in aus.
wonder if it would be worth doing a register of all stag owners
something like
series: colour: state: (plates would be optional)
yeah sorry guys i just seen the "stagea owners" thing, im a looser
Edited by loymclure
something like
could be....
http://www.skylinesaustralia.com/forums/in...howtopic=119090
That might cover it though? :D
spotted a s1 silver stagea on albert rd this evening in Albert park ... first l've seen on the road for a while.
Then 2sec's later l saw a black H2 Hummer on at least 22's on the same road. Turned onto toorak rd and saw a H1 ... damn l love those cars!!!
Spotted Christian (MRNISN) yesterday in ringwood around 12ish gave you a toot but not sure if you saw me!
I was with the misses and she yelled out Stagea as u past me, i heard u toot and only just caught a glimpse of your tail lights and red tailgate
i saw a silver stagea with the R34 front end on it in beenleigh {QLD}
ive seen it a few times now
i will have to up some pics of mine when i get a chance. {after i wash it}
ive also seen a blue one that i presume is the one from the gold coast
Edited by DevilsHatred
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
