Saw a white S1 today at the Initial Drift/SAU Drift Day - one of the very few times I turn up to an SAU event or meet-up and I'm NOT the only Stagea owner there...
That was me :stupid: i got the card you left on my window.
were you driving on the track today? or did you have your stag there aswell?
Edited by FLY PSI
Cool! Were you there with JustJap, or did you just happen to park near their truck? And where abouts are you from, roughly?
I wasn't on the track, just there to spectate. My Stag was in the parking lot...
Justjap happened to park there tow truck near my stag.
Im from Newcastle, next time your at the track if you see a purple S12 gazelle drifting, that will be me
spotted a maroon stagea on the great western highway, west bound near st marys this morning, i was parked at the maccas in the work van.
My sister says she saw two today, one was Wolverine's (she sees that car on a regular basis now as she works near his house) and a maroon one, possibly the same one you saw Andy, and maybe the same one that I saw a few times about a year ago...
Where were you Kirstie - I really must drive with my eyes open more as I never see you !!!
Was the other way heading back home...was at the lights of Ocean Reef Road and the beginning of the freeway entrance :P My little ones were the ones that saw you first :O
seen a nice Blue stagea with a rear wing and DAYZ badges.. lol chopped in front of him under full throtle and the moron that i tried to get in front of decides to cut me off still doing the 55ks luckily stageas have good brakes though :P
lol it was a very close call. luckily the gutters where the angled ones otherwise i wouldve damaged my car {AGAIN}
anyways nice car dude.. good to see another QLDER with a Stagea.
somehow i dont think he is on this site though :O
if i do see him again i will tell him about the site..
spotted a bright yellow stagea on Denny ave in Kelmscott last night. I may be wrong, but I think someone has actually bought the yellow S2 AWS has had sitting in their yard for almost 2 years.
Yes, THAT one - stock S2 RS4 (in very nice condition, I will admit) that stated off with an asking price of $29 990!!
spotted a silver stagea driving along the entrance rd going towards entrance then coming back it tooted @ us, we were all in the fountain plaza car park for the central coast thursday night meet, if ya r on here u should stop next time!
spotted(i think) stagea girl at chicken treat in waikiki,black with white rimz,also if it woz u have you seen the red stag with tha bodykit? (p plater),it my mates gf's frend lol and i have been tryin to meet her 2 see if she a member.or become one,there is 3 that i kno of in rockingham :D
hahah just trying to think when I had chicken treat :nyaanyaa:
And yeah I met the people in the red stag with the kit. Nice car... Haven't seen them since, that was at the end of last year :)
There are four of us in Rockingham :( 2 silver, a red and me :D
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
