spot the stagea
mcnamg
Spotted today at around 1.15pm: Stocko S1 silver with wheels, and no rear spoiler, somewhere near slacks creek (we were lost at the time)... Had a bigger looking guy behind the wheel, and a "baby on board" sign in the rear window.
Spotted Red S1 in Ikea car park, (Osborne Park WA). Left a sticker on it, then spoke to the female driver. Told her about next weeks run. Car had STAGEA number plates in red. Used to be in Canning vale (over a year ago).
Is there a WA Stagea owners get together next week? If so are all welcome? Time, place and date?
Cheers
James
Spotted yesterday, around 5.20pm: White stock s1, no spoiler, heading East along Markeri St, near the Q Centre. would have caught up, but I was looking for my grandma: shewrote her car off yesterday.
Spotted a Blue/black S1 stagea driving with Mr Squiggles day cruise yesterday near Caltex Toodyay rd Midvale. Stagea was dropped with gold/grey rims i think. I was in the red ford escort at the front but didnt see you again.
that is me :3some: we did the whole cruze, but took the shortcut in mundaring without noticing. heard about ur problems with the fuel pump. glad u got it running again. I know the stagea wasnt getting too happy doing that run. bewteen the auto and under bonnet heat was affecting my preformance.
But its an awesome run though
Cheers
James
sure is....This Sunday 27th "The map is now set, we will be meeting at Burswood, Burswood Carpark, Closest to Gt Eastern Hwy, at 10:30am for an 11:00am departure." BYO for picnic bbq/lunch at Kingspark....there is a thread for it go check it out :3some:
that is me :) we did the whole cruze, but took the shortcut in mundaring without noticing. heard about ur problems with the fuel pump. glad u got it running again. I know the stagea wasnt getting too happy doing that run. bewteen the auto and under bonnet heat was affecting my preformance.
Car look good mate - i only saw it from the back but it sits nice.
The gidge section just kept going and going - about 10 minute solid with the car revving above 5000rpm! :D I was actually thinking about how my stag would have taken that punishment. The cruise was probably a bit quicker than this weekends Stagea cruise but i will probably go to that aswell.
Spotted Sunday in Fredericton NSW just north of Kempsey.
Burgandy Stag with STAGEO I think or similar number plates.
Edited by ant0ny
hey, twas the missus maxing the card out at ikea. :D I bought it off justin about a year and a half ago, current in maddington so were still close by.
might see you guys at the cruise!
Shaun
spotted black series 2 this morning around 8am along jon sanders drive. waves exchanged. nice car :) (whom ever you are :D )
that was me i see your car almost everyday on my way to uni.
second time i have seen you driving.
adam.
Well nice to put a name to the wave :) I should upgrade to clear rear indicators... they look much nicer then yucky orange lol
adam.
Today I spotted a dark blue Stag along Hampton Road this afternoon about 4:30pm, female driving, smiles exchanged. :P not use to seeing other stags around freo... was a nice change :)
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
