Spotted two yesterday (NYE), both on exactly the same area of the same stretch of road, but around 10mins apart.
The first was a silver s1 (rego BAY-76Z, I think), with some silver pinstriping on the tail lights in a rectangular pattern. The second was the white s2 that I've seen quite a bit in my area over the past year or so (rego COP-003). Both spottings were on Seven Hills Rd (aka Prospect Highway) right near the intersection of Station Road, and both cars were heading away from Abbott Road and the M2...
Hey i saw the white Series 2 heading towards Seven Hills Shops on NYE too. It good to see a few more popping up around the area.
Has anyone seen mine S2 rego (BDS-22T)????
spotted silver ser1 with body kit on hervey bay esplinade looked nice, also I can't believe that after 4+ years of ownership I still have not been spotted :( I have waved to many fellow stagea owners but no spotted post :D anyway nice car who ever you were.
Edited by rb30dett
hey was it parked or driving ?
didnt see you tho unless you were one of the many drunks i drove past haha
Also today out side 'Rays Outdoors' in dandy plates were non other then ...... STAGEA
was gonna park in front of it but would of left you no room. looks very nice man
you were driving i didnt get a great look at yours but enough to get the plates,i dont have the STAGEA plates but ive seen him once or twice my plates are WGNC34
spotted a white Stagea on heatherton road about an hour ago with custom no plates.. forgot them though >.< thought it was you RBPOWA but wasnt lol
that one definitely could have been me probably dropping off the ball and chain lol
pretty sure i spotted simons old rig on canterbury rd/springy rd intersection.
had different wheels on it, but dead certain it was his. did he sell it?
white s2 in ftg, the road where maccas is. seen it a few times, was unfortunately blowing a bit of smoke :D
and a white s1 or s2 on the westgate fwy saturday or sunday...
starting to become common now.
ahhh damn you, i wanted those plates !
there is a guy on here just by pure luck his plates are standard ones WGN-342 series 2 so it makes sense
westgate freeway Saturday think it might of been between 5-7pm if so that was me.
FTG ? fountain gate ? im around there alot , gf lives near by, but no smoke from me.
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
    • Yeah good call, I will endeavour to tuck that down when I rewrap the looms it’s pushed up by
