ahahaha and another one, I'm on a roll!
White Autech Axis M35 at Lidcombe at 1pm today, nice rims.
Unfortunately I was on foot so he didn't see my Stag which was parked around the corner.
whats with chicks driving these cars now ? yes its a family car, but damn its becoming soccer mums car lol ...
5.10pm heading city in bound, passing Chadstone, silver Series 1, lady driver ...
Missus gets mine most of the time!
spotted a real f*kwit in a white S2 on Tonkin Hwy mothers day. you were stuck behind me. I was in the BA Ute all the way through Ballajura mate. you know its f*kheads like you that don't deserve the 'P' on ya windscreen. Grow the f*k up, learn to be patient and you might just not kill anyone.
OMG could jetwreck be driving slowly?? have you been hanging around andy?? :P
lol....I never speed :D .....also had about 800kg's of finished print in the back not tied down and a full tank of fuel.....she's a bit sluggish once I get her over 2,600kg's.
Love the gc hinterland, so many sights, so many Twisty's, just watch out for sunday drivers!
My top ten:
1. nerang-murwillumbah rd (Try & keep up!)
2. beechmont-binna burra rd (^^^)
3. Tambo- Mystery, Goat track, henry roberts, oxenford-tambo rd
4. springbrook rd
5. tomewin-murwillumbah rd (my fav at moment!)
6. O'rielly's guest house rd
7. Canungra rd
8. caligrabah rd!!! (air time)
9. talle valley
10. tweed coast rd
Well after reading this, I went exploring this morning in my 260RS. Not sure where I went, but went up Mystery Road, then ended up finding that one-way traffic light section, went to Canungra, then went through the back, ending up climbing up to Tamborine, then out to Oxenford and home again. Was good fun. Shame there were quite a few Sundary drivers (or Tuesday drivers) out and about :D The car loves twisty roads :P
Finally spotted in my driveway....
A fully VIC registered silver AR-X with brand new, very expensive tyres....
So I guess I will be dropping by on the weekend then?
As an aside, how have I not been spotted yet?
Been driving my M35 since April '07, everyday, everywhere.
Maybe I need to do an interstate run... :)
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
