Light blue or dark blue M35?
Where?
ah it was a darker blue and i think it was on the Nepean highway near Mentone area... i think can't remember now
Always nice to see a fellow stag owner n give a wave :P we're like motorcyclist
Spotted a whole heap of M35's at the Stagea meet tonight.
Thanks for the venue Jetwreck.
you didnt mention spotting a blue fiat 500. i feel a bit left out!
Not to mention that awesome dark green s1 C34!
I am sure you would have felt left out turning up to a Stagea meet in Fiat.....LOL
Bloody weirdo - 'sif blame it on the wife for needing the Stagea to transport a bunch of her friends into the city or what-not...
nah i didnt, mostly because i had the best handling car there. ohh and most fuel efficient. and i could beat craig on a take off too :thumbsup:
'sif best handling, too...
Are you telling me that your Fiat is faster than a Mazda 121....... Wow.
LOL!!!
i had some fun in the traffic on the way home from work today with a WRX, the fiat is VERY nimble and in traffic its probably the best car ive owned for traffic thrashing
Now hat is just Blasphemy.....LOL
spotted in currimundi on sunshine coast dark red m35 arx. steve is the owner, pulled over to have a chat.He will have a look on this site. dead keen for more info on his pride and joy. :)
I forgot to mention that on Tuesday night I spotted a dark (not sure what colour, noticed it at the last minute, and it was dark) C34 Stagea on Greystanes Road in Greystanes - it was around 7.30pm-ish.
u were about 2 cars back from the roundabout in the right lane headed from dural, and
i was coming from county drive going across-ways into shepherds drive going into cherrybrook.
i went thru pretty quick as it was sorta pissing down
Spotted Silver M35 RX (XCF799) on Whitehorse Road heading from Box Hill eastwards. I was behind him in mine then pulled up beside him in before he turned off towards Blackburn. Honked the horn, he looked but no real response. Not sure if it would be anyone on here?? Asian fella...
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
