You guys might see my GF getting around in North Rocks in the next week or so. She has my stag down there till I get there - and even then I doubt she'll get out of it. Apparently my driving is unique. It's been down there since the 28th and I haven't had it since the 26th :banana:
We know very few people down there and I've been trying to convince her all stag owners are awesome so if you see her parked say hello and be hell friendly so I am proved right :P
Plates are XXX-LUB - she'll have a Dalmatian in the car with her a fair bit. It also has some ridiculous dally sticker that she thought she'd put on my side window. Yes. I told her no stickers. Naturally, I was ignored.
Edited by LordMidol
i live before pemulwuy if you turn on from the hwy
close tho :)
should have been me.
LOL, did I just see you again in North Parramatta, on Church Street? I saw you wave, but didn't get time to wave in return, but I did beep.
Nick that was me! damn I had to drive to Parra to actually get spotted!! nice car and I did get the beep!
also on the 1st on windsor rd near the fiddler a white rs4 clean think it had no rear wing??? we both said hello to each other at the lights :)
also on the 1st on windsor rd near the fiddler a white rs4 clean think it had no rear wing??? we both said hello to each other at the lights :geek:
Ahh was it? I only live in Toonie (as does StageIan, barely 2mins drive away). It seems that there are quite a few of us in the Parra/Holroyd/Blacktown areas, so why don't we cross paths more often?
Why not a western syd meet? after I get back from driving to cairns...
You guys might see my GF getting around in North Rocks in the next week or so. She has my stag down there till I get there - and even then I doubt she'll get out of it. Apparently my driving is unique. It's been down there since the 28th and I haven't had it since the 26th ;)
We know very few people down there and I've been trying to convince her all stag owners are awesome so if you see her parked say hello and be hell friendly so I am proved right :bunny:
It is easier to spot with that ridiculous sticker. When you get back I will get a proper one right across the back window. oh yes.
Spotted white c34 today on the Monash, just past Springvale road around 1pm. Was it you TJ?
That definitely couldve been me heading to my gf's place,if i missed you in your stag i am devestated normally my stegea-sense starts tingling
lol
a schmick looking yellow s2 yesterday just south of ballina heading sth didn't get the rego but exchanged the secret stagea greeting
That was me! Went camping for a few nights, but it rained! :)
Yours looks sweet - love that front bar!
Spotted a Pink :D M35 in Blacktown las tnight.....pretty sure it was Steve.
Ahem... how did you know I would find this and bite? :)
Sorry havn't been on for ages guys, work has been flat out and the commuting is killing me. Just glad I'm in the Stagea and not shittyrail :)
Have 2nd week of feb off so all going to plan I am finally getting to SAS for the remap and then it's time to start planning the turbo upgrade etc. I'm not getting anywhere near the same money in the new job as I was with the government which is a major bummer! :(
BTW Craig, love the Nismo decals ;)
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
