spotted a white s2 on windsor road, around box hill this afternoon around 530...
Saw the same nice white S2 on windsor road at rouse hill around 5:25. Given the area, thought it was CL11QE but when I caught up found that it was COP:???
As it turns out, CL11QE must have been just over the next hill...
Didn't get a wave from COP:??? Perhaps no recognition for an M35... where's the Stagea love?
I was at stuck behind a truck and a red light on nelson road waiting to turn right onto windsor rd northbound,
which was the same direction the other white one was cruising but i was at the lights for so long i didnt even
bother trying to find it....
ahh Keysborough is becoming the New Adelaide,
pulling out of my driveway m35 with half a front bar drove past my house, gave a wave,
further down my street i see him pull into the importers so, might not be his but still a spot!
parked further down the road outside a jap second hand parts place, a Blue s1 without.
see all kinds of random stagea's down my street, dont forget the time the importer was taking a 260rs for a test drive, had no mufflers or cat! its was FOB very nice sound and flames as he down geared for the corner!
:( I assume it was white? That is Alex and I imagine he had a pearl blue front bar in the back :D
Edited by iamhe77
spotted today around lunch time: my car on th back of a flatbed :blink:
Looks like I'm up for a new fuel pump, so it's no great disaster. However, upon pushing the car, we discovered that one of the diffs is binding, which would explain why it's been feeling a little flat lately, so I'll probably replace both with closer ratio units...
Hopefully, I'll spot it in my carport again next week....
spotted STAG 34 just then at the BP Subway on Beach Rd. We were going to say Hi on our way out but just as we got there you started ordering and we didn't want to interrupt.
You parked next to my Series 2 :blink:
nah no blue rear bar, was gonna tell him about your front bar you have for sale haha.
spotted my car on the Flatbed also this morning at 1am, should of gotten a photo!
but before all that, spotted and Series 2 days at a car wash at BP in Doncaster, around 830pm i think, had those round front lights in the bar also, was gonna come say hi, but was really in a rush.
Spotted on Monday what looked to b a autech 35 silver can't remeber plates on newbrige rd in Liverpool looked like it was lowered with the factory rims and if you on here I think u were with ur other half It would have been about 1030 -11 am I was going in the opposite direction on the bridge would have waved or flashed but I can't multi task I was overtaking on the other side of the road
Nice looking stag btw
cheers
Damo
Spotted a white C34(running!!!!) on Epping road this morning at about 7AM...coming out of the Caltex servo. I was in my wife's U13 Bluebird(also running)!!!!......because my piece of F$#King useless scrap metal shitbox m35 is broken again!!!!! :thumbsup: .....yes again!!!!!!
VENT finished!!!!! :P
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
    • Is the problem that we just disconnected the line, does it need to be plugged? I’d rather not buy another master cylinder
    • Clutch is same same. Tailshaft is not. Diff will drop in. Half-shafts will not mate up (5x1 on turbo, 3x2 on NA). There is also the strong possibility that your auto NA gets its speed signal from the sensor on the diff, not the gearbag, and that will leave you without a speedo. You can do all this, you just have to do a lot more than you thought.
