LOL - Craig, what are you doing helping the "Mexicans?" Soon they'll take us for fools and want to cross the border...
:P:):bunny:
:laugh:
Everytime I here you NSW'ers call us Mexicans, I can't help but thing that you are referring to yourselves as Yanks! :wacko:
Spotted a red S1 this morning heading north on the Brisbane motorway. Never realized how nice the fog lamps look on the S1's. Reminds me of my old Silvia but bigger. Way better then stock S2's and better looking then factory extra ones aswell.
Spotted andy65b about an hour ago near Chatswood. Nice shiny metal behind your front bar there! You going to tell us all how it performs??
Yes, nice shinny bits in the front. I will post up later tonight how it works but it is good.
white s1 at the back of granville tafe friday arvo
Dude, you had two s1's right in your neck of the woods last night - we had a dyno day at Unigroup and went to Fully Tabouli at Pemulwuy shops last night afterwards...
spotted a yellow ser2 in the capalaba area about a week or two ago.
i would have thought with all the driving around ive been doin i woulda been spotted more. oh well, if u guys cant spot me the cops have got no chance. hehehe just kidding
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
