yeah i have the same blue stagea and have met her husband. He is more the car guy... but she waves when she sees me now :blink: its annoying having a similar stagea to mine so close!
You will know if its mine though, its lower with 19" enkies :P
But I dont think i have been spotted yet!
Spotted a very nice dark blue M35 on it's way up Kariong Mountain at about 2:45pm, I was heading down the mountain and only caught it out the corner of my eye at the last minute. Didn't have time for a flash or a beep.
If you are on the forum hello :P
I know someone at Green Point brought a stag recently but not sure if this is the one.
yeah i have the same blue stagea and have met her husband. He is more the car guy... but she waves when she sees me now :down: its annoying having a similar stagea to mine so close!
You will know if its mine though, its lower with 19" enkies :)
You sure this spot I made above wasn't you?
yeah i have the same blue stagea and have met her husband. He is more the car guy... but she waves when she sees me now :) its annoying having a similar stagea to mine so close!
You will know if its mine though, its lower with 19" enkies :D
Don't think it was yours: pretty sure it had factory rims, ánd maybe an exhaust/muffler...
yeah i have the same blue stagea and have met her husband. He is more the car guy... but she waves when she sees me now :P its annoying having a similar stagea to mine so close!
If you were in Manly last night, along the beachfront, then consider yourself SPOTTED!! :)
spotted a white c34 at kings park/kings langley at about 2.30pm today, flashed my lights a few times but I don't think he twigged.
i was on my way down to the shops on a beer run :)
I was up around there over the weekend. If it had ARX wheels it was me.
not sure ive only caught a glimpse of it twice and it was a while ago
once was on medowie rd medowie i was parked and once on honeysuckle it was parked and there was a grey 1 near buy also parked
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
