woop :)
good having a chat with some stagea owners finally.
saw a green s1 l plater on the way out too
Was good to finally meet you too, dude (and Teren, too)!
That other green s1 I'm pretty sure:
was Hugh's son's green s1 25G (now there are triplet dark green s1's :P) and a white s2 as I was leaving.
gold m35 arx turning onto sunnyholt rd at parklea... L plate driver, the look on the driver was priceless.
I assume you mean L plater driving the ARX? Have to be a PM35 wouldn't it?
I didn't think L plater's could drive turbo vehicles?!
Pretty sure L platers can (cause they are under supervision or something), just P platers who aren't allowed to.
I stand corrected! my bad, I spose I just assumed if P plater's could drive turbo's that L Plater's couldn't either.
spotted Bis-e Bee driving past my work today.
You've had a lot of cars there of late, even of the evening!! Now I assume you don't live there so you must be having lots of work parties? :D
I also spotted your silver skyline in the driveway too :)
yeh my missus is learning on my stag, though i hold the stearing wheel while she's driving lol.
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
