spotted a silver c34 on dandy and warrigal road today exchanged waves...spoke to the owner of the blue stag in richmond once his wife drives it and was looking to sell it she did not want manual anymore
that was me in chaddy, have seen you a couple of times on dandy road, we must finnish work around the same time
may not be me you see only went that way due to freeway blocked off normally on dandy road for 200 meters to get on to blackburn road
spotted a grey m35 stag yesterday around 12:40 - 1:00pm at the corner of Canterbury & Mitcham rd, waiting to turn.
nearly went through on the red arrow and backed up a bit :down: lol.
gave you a toot as i was turning right.
spotted last night around 9.00pm: silver S2 (maybe had rims?) heading West on Mona Vale Rd near Frenchs Forest. Was in my other car, and he/she was moving at speed, so no chance to acknowledge ...
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
