I came across this website yesterday, surprised to see that Stagea's are so well supported. I've been using a 1997 RS Four as a site car in Micronesia for the last couple if years and given it quite a lot of stick, need to keep it going for another year to see this project through. Suppose you could add this to the spotted list
There were 12 , including the uber cool bastard that just drove past and did not stop - like your style - sunday 24th oct 2010 , since being ousted from the GTROC UK ! the stagers owners club have been positive in there coming together and surviving quite nicely . more shots here http://www.facebook.com/home.php?#!/al...p;id=1311100133
Second time I have seen him.. I have to ask though it's looks way lower then mine and I struggle so much with bottoming out on speeds bumps, carparks etc. Does yours scrape alot??
Its not too bad. A bit of angle gets me over most things untouched. I originally had it about 2cm lower than it currently is and it was a nightmare, but seems perfect now.
I'm disappointed that I DIDN'T see a Stagea up for the challenge against the Merc AMG SLS, the Porsche 997 911 turbo and Audi R8 v10 - I think it would have kicked some butt!!!!! :P:D
I tried a few times.. but was disappointed.. :down:
^^ might come next week!! When and where??
Spotted spoolin this morning on my way to work in frenchs forest
http://www.skylinesaustralia.com/forums/ca...&hl=Coastie
Every Thursday night (I'm there almost every week, but sometimes I head up early so I don't stop at Berowra because there''d be no-one there).
    • How much ya asking drunkan
    • A few other things to round out the chassis mechanical checks. Diff is nice and full of new oil, pretty sure it is Castrol VMX (I run the same on Award's recommendation). I didn't pull the cover to check, but I'm 90% sure the diff centre is a nismo mechanical (old school, not the gt pro). Gearbox is also nice and full of fresh oil, not sure what it is but not redline. Tailshaft bearing looks OK and a tailshaft loop is in place
    • Front lower control arm is standard with new ball joints, tension rod looks like JJR spherical. Front upper control arm is standard with adjustable bushes in the outside end     Rear arms are all nismo, surprisingly all the bushes at either end look standard but in good condition Subframe has standard bushes with lock collars HICAS has a lock bar with standard ball joints at the hub end
    • Next, shocks/springs/swaybars It has Sydneykid valved Bilsteins with HKS pillow ball hats all round. Springs are Eibach race springs on adjustable height platforms, with helper springs in the rear to stop rattling. These are 250 all around but easy to change for something else if required. Swaybars are powdercoated blue but would be Selby's/Whiteline solid adjustables, 21mm rear and 24mm front. Bushes and links in good condition All in good condition, no sign of leaks/damage etc
    • yeah for sure.....remember to put your tools away at the end of each day kids!  Actually it has been kinda nice working on the car, lots of memories of good times. I can pretty much hear him telling me off for stuff still.
