Sweet looking car man.. I got all excited like a little school girl when i saw it lol.. Its rare to see another stagea here, Wanted to say hi but when i came out of jb you were gone
Thank you, That is where I was also.. too much playing on the PS3. lol
OH what... damn it. you would have walked past me then... :(
xbox360 or ps3.. i have both just depends on the games you want to play...
StageIan said Nick had to pull out at the last minute :(
Had a great time myself... pity we couldn't round up some more Stageas. Well done on a great event.
I dont know if there was a pun intended but LOL
Saw a silver C34 at Wentworth Falls traffic lights this morning around 8:50am. Gave a wave but not sure whether you saw me.
Also saw a silver M35 on Boundary St Chatswood today around 10:15am. Older bloke driving - had wooden steering wheel plus the front bar similar to bbenny's with the fog lights. Factory 17's on it.
OMG I spotted a red C34 and a gunmetal M35 on the putty rd yesterday.
no green C34 which was unusual?
Yeah, I had a fairly late night on Saturday night, but decided I'd set an alarm and see how I felt when I woke up, then make a decision on whether or not to attend then. Woke up, still felt tired, but then couldn't get back to sleep for ages. >_<
In retrospect, I should have asked Ian if I could get a lift with him, then grabbed the camera and shot photos all day while passengering. Oh well...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
