Spotted (Iains) Awesome car today - the Silver version. St Ives, about 430pm
no you didnt
at 4.30 i was in leichardt lol
there is clearly someone trying to imitate me. not surprised due to the awesomeness i have
Not that anyone else will know where it is but spotted the 8th Stagea that i've seen in Townsville at the Dalrymple Rd council depot, silver RS4S appears stock. There's not 8 still here as atleast 2 have moved and haven't seen the others for a while but thought i'd post anyway. I think i'm the only stagea owner in the ville thats on this forum.
Had a 2 day trip to Canberra for work and spotted a couple on Monday at about 12:30 i spotted a Silver S1 C34 in Queanbeyan out the front of the Vets on Yass Rd.
and also saw a White RS260 at Canberra Airport in a carpark off Glenora Dr.
no you didnt
Probably myself, new to the forum, new to owning a stagea (very impressed) and yet to really post on here.
Btw it lives on the nthn beaches ;)
Cheers
Nick
Cheers
Nick
do you have the nismo side stripes??
if you do, youll have to remove them unless you bring your car for a nismo ECU inspection :P
you need to earn the stripes.
also, congrats on the ride :)
If memory serves, that isnt the order other people applied them in :nyaanyaa:
    • Sikaflex. There are many grades. I'm not sure which one is generally used for this purpose though.
    • Yes, and you will never get the shock to go onto the pin with the ARB loaded across the car like that. Too much force.
    • One other thing worth mentioning when I did this job I only jacked up the driver side as I was only doing work there, but from what I understand both wheels should be in the air when removing the sway bar links?
    • Yep it's an r34. Usually people remove struts without removing the front upper control arm (fuca is what i assume this is?) So not sure why mine wouldn't fit. I know on my other car I did a similar job and it wouldn't fit until I removes the ball joint nut even though I didn't remove it prior.   The upper arm doesn't seem to be in the way (the part that's bolted to the chassis. The part that's bolted onto the j arm I'll check that out though.   I was going to compress the spring and put it in with the compressor attached but not sure if it will work  Haven't seen anyone do it.
    • I have a small lip on the boot of the E90 and I've been toying with the idea of trying to mould it in to the boot to remove the gaps. I guess shaving the seams? No idea what the terminology is here.  What I'm wondering is, if it's current double sided taped down, what would I do to more permanently attach it so it makes a good base for the filler? It only has edges so no way to bolt it down unless I add some braces. I've done a lot of fibre glassing in my time so that's nice and easy but I'm not sure what my options are here.  Sorry, this is the best pic I have and I'm 4 million ks from home ATM.
