In Sydney for a couple of days for work. About 100m down the road from the hotel see a Gold AR-X, reg KNG35M. Nismo wing, black wheels with chrome lip, quad pipes, black tint, Dolphin grill and Maserati badge on the boot...
With a Maser badge ?? WTF? Lol
Good to cross paths again, it's been a while.
The brakes are actually why I was there..... while they do technically "fit" under the current rims, they are so close that you can't put balancing weights on the wheels, and it's finally tipped me over the edge to grab some larger wheels.
Did you get th oil change done OK?
Yes no worries with all good some chrono 300v and filter should do the trick, However mate of mine while checking it all out discovered small oil/fluid leak near diff. We figured it was directly below where diff filler screw is and it's filler screw not tighten just finger tight damit.
It was the knobs at nissan in Rockdale who changed diff fluid couple of months back just hopeless.
It pays to do it yourself or with your handy mate sometimes.
Cheers
Dave
Spotted a real deep blue stagea in gawler SA near trinity about 5pm looked very clean...didn't know it come out it that colour tho...the guy driving looked like he was going through his mid life crisis
Spotted a dark grey M35 with the AR-X/Autech Axis flares, but they were in body colour and it looked a bit too low to be an Axis, so maybe it was an s2 AR-X? Saw it parked in the carpark of Westpoint at Blacktown, around 2pm today.
cut out the midlife crisis stuff mate :thumbsup: you dont have to be young and cool to own a stagea, you can be midlife and cool :cheers:
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
