Spotted Silver PNM35 while stuck in accident traffic on the M4 tonight.
Stock standard; blank canvas!
Also saw yellow C34 leaving the freeway while I was stuck in the traffic.
VIC traffic is way worse imo!
Ooo! New PM35 !
At least you had fans in traffic this time!
Btw, spotted the bluebird tonight, would it hurt just to wash it once a year?whistling.gif
Lol Alex, it looked exactly like yours did; Pre- Mods.
Spotted about 20 min ago: white M35 with black wheels and lip kit, being driven by a lady from Un iversity drive, along Cottesloe Drive in Robina. I stayed alongside admiring it for a short while: very neat looking car: I was in the Black BMW 5 series.action-smiley-069.gif
spotted a white C34 S2 parked on North Steyne @ manly just before 1pm
and also spotted (i forget his name) M35 - plates "SBxxBS" on Raglan St @ Manly also, gave him a thumbs up as i passed him in my work van :action-smiley-069:
haha, finally! spotted, after 2 years.
yeah thats my piglet, spotted you around a couple of times too! :D
Nice, glad someone finally spotted you, technically my first spot too. do you live around the area?
yours looked like a nice Stag, what's done to it?
Thats Spoolin12- Chris
Also known to stick his number plate on Lamborghinis!
Oh, and better keep on topic- the C34 Mailcall courier Stagea went past my place today! Still wonder if he is on here!
Edited by PN-Mad
Spotted Duncan on his way out of the City on the free way at Naremburn, didn't see me because he was to busy giving it the boot. whistling.gif
haha I don't boot it until I get out of Lane Cove Tunnel....you must have seen me cruising :banana:
spotted Andy yesterday afternoon in another sort of wagon. skoda octavia RS. i think it was an oil burner...........
Correct.... Oil burning Octavia RS with a little bit of tweeking.. :)
Back in my new Work Van now.. Oil burning again .. Transporter 4motion crew van with twin turbo... :)
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
