I spot a Silver S2 Stagea with dolphin? bodykit on the cumberland hwy frequently. Normally around 7-7:30pm weeknights.
Saw Dale's M35 today, never really seen an M35 up close. Boy they are nice!
Cheers Adam, looking forward to seeing some tough rims on yours!
Enjoy the bars mate. ;)
Red c34 s2 with L-plates leaving the Bunnings car park in Villawood (near Woodville Road) on Sunday around 5pm, might have been the same car Raf spotted at Canley Vale.
Yeh would be cause spotted him around 5:20ish
That would've been me! Big night out at the movie haha. Cheers for the spot!
Haha just had dinner at spargos! You don't happen to live in Woodcroft do you? There's one down the road from me that's blue!
both you guys coming on the stage cruise?
Hah, yeah I live in Woodcroft, small world!! I probably have seen you around, what does yours look like? I've seen a couple in this area. Yup, im definitely going on the cruise, a bit new to the whole scene though.
Haha yea it is! Mines a silver s2 rs4s with 34 gtt wheels. Looks stock ATM lol I'm across the road of woolworths lol
Saw over the course of the weekend that was the Skyline Nationals 2012 in Goulburn- a Gent with a Lovely Blue PNM35 AR-X (Sorry I forgot your username, but your down Queanbeyan way)
Both Jetwreck and Scotty sans M35's
Andys old ARX that was doing 1:17s round wakefield on sunday- and won a track day prize in category!
A Silver C34 in the wakefield paddock
A great looking White PM35 with infiniti brake upgrade also in the wakefield- should have said Hi when you walked past!
And heaps of other cool Nissan cars....
where's the pic's :P
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
