Spot a very nice s2, bayside blue, regularly around my place on hawker street. Sa. Normally parked down a side street between the park and the pub! Just wondering if you're on here. Good to see another one in brompton!
a little delayed but during the last 2 weeks ive seen 2 white m35's, a maroon c34, a white c34, bayside blue c34 oh and finally another white c34 with a tribal decal across the doors :D
all around the northern suburbs
Spotted a red stagea with a black front bar last week, once outside Hardware and General / Chickens Plus in Brookvale, and the other time was in Neutral Bay, outside NAB.
Also spotted a black stagea this arvo outside NAB again at the traffic lights. Gave the nod, got one back. On here?
Edited by XS80ST
black s2
on marion road, thismorning, not sure what time, went past graham wests workshop! we were having a dyno get toether! wishing my stag was on the road so i could have shown them a real car!
Spotted that silver M35 again parked on Targo Road in Toongabbie.
That's always parked near the park on the corner at the end of Targo hey? I think a chick drives it, I live down Targo Rd too but mines never on the street.
Spotted Nick, Duncan, and a mystery White m35 at the sau nsw dyno day yesterday. M35 was just hanging out at a tyre store opposite unigroup in Windsor.
Great to see Duncan's dirty 30, and Nicks clean car on the rollers.
I've been thinking of leaving an SAU business card on the car, but everytime I see it I'm either in too much of a hurry to get somewhere or too tired to do it.
You live down Targo or on Targo? I'm on the other side of the station in Toonie, but my car also spends 95% of its home time in the garage.
Clean car? Mine? LOL! :D
Hahahaha :P
My dyno prediction was spot-on though - 175rwkW on the first run and a max of 176.2rwkW. AFM was maxed-out, and the knock sensor was going crazy (reading up to 170!) even though there was no knock.
I've lost about 10kW over the past few years, but that was measured on a different shop's dyno and apart from the usual oils and filters, etc. I haven't had to do any maintenance.
Didn't spot either of the 2 stagea's in Germany but did spot plenty of BMW's & Audi's on the Autobahn.. got to love those Autobahn's... 196km/h in a 1.4lt compact. :)
How is this possible???? :woot:
Speed kills; therefore you are dead.
Congratulations on your internet connection from the afterlife. ;)
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
