Was he racing? would be a hard task making our cars fast down an 1/8 mile
You kidding? 1/8 mile is the M35 event. 4WD out of the hole & it's all over before the other guys get a chance to catch up, lol.
No he wasn't racing - we were spectators today. Maybe another time..
maybe if our cars were 500kg lighter. and able to launch propely
spotted very nice gold m35 in burwood today, looked but couldnt tell if u saw the silver stag on how tinted your windows were lol
That was me! Yea, I was waving and wondered why you didn't wave back. Nice C34!!!
Saturday night there was a dark coloured C34 parked opposite Werrington Down shops / Caltex servo.
Sunday morning spotted a black M35 on Cumberland Hwy / James Ruse Dr near the underpass of Windsor Rd. (North Parramatta) at about 10:30ish
and today spotted Taren in his C34/R34 black wagon on Castlereigh Rd around 1:10........ I was on the side of the road in the van on the phone :P
Black m35 was me. I live in northmead and was on my way home from the fully sick nismo workshop
Also spotted a silver C34 at Glenwood shops tonight around 530pm
Spotted 2 today...both in port Melbourne .... White S2.. stopped him and and a chat.. Sorry I didn't get your name... then while waiting for my bus around 5:45 an M35 went around the corner from salmon st on to Williamson road.
Edited by infiltrator
Yeah, I did a 6.2 sec for the 1/8 mile ROFL
red c34 stagea with black aftermarket front bar in roger st brookvale
you drive past my work most mornings and i spotted you around 12 on pittwater rd driving past again :yes:
Edited by R33huntme
Yep thats me...
I take it yours is the grey one parked in roger st I see in the mornings. Looks sweet.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
