Spotted very slick C34 waiting to pull out onto GWH at Springwood yesterday; gave a flash, got a wave back.
Nice ride mate.;-)
That was the son,s car. Now you have seen the family's full collection :banana:
Was being stalked by #@Old Fella in Emu Plains today; apologies for having to look at the back of my Brown Stagea today.
Yours was looking immaculate as usual...
Must stop for a chat when I next see you; unfortunately was on my way to a funeral today.
This afternoon, I spotted that white S2 C34 that's regularly parked on/near Powers Road in Seven Hills. Looks like a trailer was attached to it, or it was very closely parked to the tow hitch on it.
That's generally where you are going in a hearse
Son and myself (C34 and M35) turned up at the daughters house and neighbour she was talking with said "Here are the two White Lady funeral cars arriving"
  • Like 2
Spotted Josh aka "Brick" @ my work tonight swapping exhausts
Really?
I actually had some respect for him, as I'd assumed he did it in the apartment parking space.
You've made things too easy for him Dave.
  • Like 2
Silver NM35 spotted lurking around garage sales in Wentworth Falls this morning.
Yes, I spotted it too? at the Old Bathurst Rd roundabout near the Blackburn Hotel in Katoomba yesterday. I waved to the driver as I turned off the roundabout and received a nod in reply.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
