Spotted a Gold ARX on Pennant Hills road around 12.30 today. It turned right at Pennant Hills. I think it was probably Danny.
Tooted and waved but he was in the right turn lane and I was in the curb lane.
Cheers
Andy
Cheers
Andy
heya prbably was me :D
Spotted s1 green driving from brunswick juction to perth . And yes dale it was your car straight and driving again . All is looking good and be looking at getting it registered again very soon . Great drive couple of little issues but will be sorted .
  atomaly said:
spotted a white (S2 i think) right outside the carwash on corner of Springvale Rd and wells last night :(
flashed my lights
think they spotted me too :)
i wanted to say that this was me but i cant remember lol, i have seen you round once or twice though. Did you happen to get your car from SSV, they had a black one a while back i went to have a look at to suss out piping for my FMIC. its a terrific looking car mate :D
  zei20l said:
we all seem to spot that white M35. no one knows who he is lol
Yeah, I was flying past in the truck........last second spot. Had black surounds over the guards.
Need to work on my quick draw with the camera.......
  WGNC-34 said:
i wanted to say that this was me but i cant remember lol, i have seen you round once or twice though. Did you happen to get your car from SSV, they had a black one a while back i went to have a look at to suss out piping for my FMIC. its a terrific looking car mate :)
thats exactly where i got it from :cool: i kept seeing it there when i drove past every now and then. and i'm like... if its there next time i go past.. im gonna test drive it... and then once i did that of COURSE i had to buy it :)
i'll PM u i think i remember the plate :P
i used to always see a silver RS4 in the same spot aswell (before i had mine) and id have drool on the dash by the time it had gone :wave:
  atomaly said:
spotted a white (S2 i think) right outside the carwash on corner of Springvale Rd and wells last night :D
flashed my lights
Probably us but we didn't see you dude. :D
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
