Spotted!
Pearl white autech yesterday morning corner of Centre Dandenong and Warrigal Roads...
I was in the van, hot looking car...
haha that would have been me :D i have seen probably 4 stags in the last 2 weeks. Even 1 Blue M35.. things are becoming common! haha
Light blue or dark blue M35?
Where?
Edited by iamhe77
Spotted a White S1 Autech 260RS on Wurundjeri Way heading towards filders street. If your on here nice looking car mate, i drove past on the opposite side of the road in my Silver S1 RS-Four V.
hmm this coulda been me 2... i was in the area at that time. 2 spottos in a couple of weeks... didn't realise the car was that loud hehe i know its loud inside :D
hmm this coulda been me 2... i was in the area at that time. 2 spottos in a couple of weeks... didn't realise the car was that loud hehe i know its loud inside :P
I was to busy staring and was gonna beep the horn to get your attention but it was to late :D...
Spotted a whole heap of M35's at the Stagea meet tonight.
Thanks for the venue Jetwreck.
Spotted a light metalic green C34 on the wa home heading wes on Victoria road through West Ryde. Number plate UFO ___
you didnt mention spotting a blue fiat 500. i feel a bit left out!
nah i didnt, mostly because i had the best handling car there. ohh and most fuel efficient. and i could beat craig on a take off too :P
Are you telling me that your Fiat is faster than a Mazda 121....... Wow.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
