no they dont, but they let people know there is a nismo ECU on board :P
Not to mention other Nismo part'sthumbsup.gif....other than a thermostat that is!
Edited by Jetwreck
I spotted a silver NM35 AXIS last night just before 7pm, I was heading North on the F3 freeway and about to take the Berowra exit, the AXIS was heading in the opposite direction.
Spotted 3 in 3 days...white c34 on annangrove rd wed afternoon, silver rs four s turning right onto schofields rd with me on thurs morning, and the a red c34 on parramatta rd near the start of the m4 tonight around 9...
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
