Saw a white or silver RSfour with a Dayz kit, did manage to spot a nice front mount hidden away there. Spotted roughly a hour to a hour and a half ago going towards seaford from port noarlunga.
so on wednesday my car goes into boss tuning to get my shutter in the left wheel sorted out i only have one day to fix it it should only be a cv joint easy then off to get nistune cant wait so excited i want 13.00 at eastern creek on the 9th july and i am going to get it
on the way back from Nelsons Bay "GO00LD" (I think) and his white s1 removal truck drove together for about 15km or so...
Very impressed how that wagon hauled that trailer with a full boot... easily kept 110km/h...
Helen & I just parked behind silver S1 across from Toony pub, rego BCG-???. W we're in the Masala Inn having lunch.
Did it have black (or very dark grey/gunmetal) wheels on it, Ian? It might be the one I see fairly often on Targo Road.
Who ownes the stagea at boss tuning I have never looked under the new stagea
Like the new swaybars they are bloody thick nice
Car belongs to Roullos. I believe his Stagea was at the repairer behind Carline having some paint repairs prior to turning up at Boss.
Whiteline Sway bars from my Group Buy. Need some Whiteline parts?:whistling:
no one spotted me broken down on windsor road tonight?
friggen AFM died at around 6000rpm while i was a little sideways lol
thanks to jetwreck for the phone diagnosis. i thought it was a CAS. much easier to drive without an AFM
Bugger! I take it you just unplugged and drove in "limp mode"?
Lucky you have a spare...:whistling:
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
