Spotted some of the usual suspects at the jaf cruise last night me and dream 15 "iculkn" are starting to wonder if we are lepers or if its just jealousy that leads to being ignored by some bit sad really
spotted a blue M35 RS/RX around the Northbridge area parked out side a house yesterdat around 2:30pm
and then spotted a burgandy M35 ARX (with a checky money sticker in the back window and nismo sticker on the bumper) driving down Concord Rd, Rhodes. I was behind you dont know if you saw me but i turned down Homebushbay Dr. that was around 5pm'ish
Silver s1 rs4 at olympic dam, roxby downs.
A little unusual around this neck of the woods
Pffttt... ya not wrong. That'd be Landcruiser territory wouldnt it???
http://maps.google.com.au/maps?q=olympic+dam+&hl=en&ll=-31.278551,140.19104&spn=4.013594,8.453979&sll=-30.911651,139.356079&sspn=4.029111,10.546875&vpsrc=6&hnear=Olympic+Dam+South+Australia&t=h&z=8
Haha nearly is, there is normal roads out here :-)
I have seen a legnum, r32 gtst, r34 gtr and heard about a r35 gtr out here before.
Spotted a Silver S1 Stag Cruise past me the other night at 7.05pm at cnr of Highbury & Blackburn Rd Mt Waverly/E.Burwood where H.Jacks is. Was on Blacky Rd heading in Blacky direction.
Has STAGEA down the side on the doors, plates were MRNISIN (i think, i was hidden next to a mini bus, last second spot).
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
