spotted black low M35 stagea turning right away from muno para shopping centre today around 10.50 and then a silver one about 10-15 min later around the parafield area on main north rd as well. both looked great.
Reckon that could have been me in the black one. Silver wheels?
Edited by jasevr4
Spotted this Stagea at Tokyo Autosalon with a few drift cars. It had a video playing on the iPad that showed 4 Stageas drifting.
Quick video of the iPad:
Slightly off-topic, but I also got to see the Mazda 787B start up. One of the best automotive experiences of my life. I took this vid:
spotted 3 on the way into the city on the way back from the cruise today.
a white C34 on maroondah highway at mitchum i think, he gave me a toot he was turning right, had a few stickers on the rear window.
2nd was a silver c34 on blackburn rd, was turning off blackbrun rd, i gave a wave.
3rd was also on blackburn rd, parked it was also a silver c34 but had some red and black pinstriping.
The white C34 was mine man,was good to see another RS4S :thumbsup:
HELL YEAH!!!! go the 26B!!!!!!!!
Spotted and went out to lunch with StageIan and his fiancee on Sunday, then saw him again tonight went we took both cars out for a quick photoshoot meet-up in Norwest. There was another Stagea there (black or very dark purple s2) parked at the meeting spot for tonight's shoot, but didn't see the owner.
Spotted a slightly dirty (and maybe worse-for-wear - couldn't tell for sure because it was after dark) silver M35 RX/RS doing laps of George Street/Horwood Parade in Parramatta, quite possibly looking for parking in the area. This was around 8.45pm on Thursday night (Australia Day).
Today, spotted StageIan in his red s2 C34 on Old Windsor Rd (or Briens Rd, whatever that particular stretch is) in Northmead, roughly 7pm.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
