saw RBPOWA (SP) on glynburn road.
That would be me. I take it u were in the s2 rs?
Also spotted a s2 bayside blue at the bp on lower north east rd as I pulled in to get fuel u were leaving
white C34 with gold/bronze rims weaving in and out of traffic, from the M4 all the way up to ryde this afternoon. in my black 34, no love shown =(
:action-smiley-069: hi Chris, sorry too busy hooning to wave :) Nice 34 BTW
Spotted a Black S2 Stagea a few times now around Burwood East over last 2-3months on Highbury Rd and Blackburn Rd
Same with a White S2, also keep seeing a White M35 in same area. Sometimes up on Springvale Rd.
Exchanged headlights, waves, toot the horn a few times.
Yellow S2 Stagea with R34 kit also in same area also.
Got a thumbs up and a wave from the bloke with the other silver m35 down the end of Targo Rd on the weekend.
Dave, it wasn't you I saw the other night on Gilba Road (crossing Targo) and then again about 20mins later in Toongabbie near the servo on Cornelia?
Hey mate, yeh I saw your post, and the times were near when I was getting around those areas, but I turn left from Targo onto Gilba, and you mentioned Junia and Cornelia? I was parked in the servo on Cornelia that's opposite toongabbie shops, I just re-read your post I thought u said Lucretia and Cornelia, not Junia, but yeh for sure that would have been me then :)
Edited by DaveM35
That was me in the Black C34.....probably wont be seeing you on Highbury Rd anymore as Im not working at the same place anymore so taking a different route to work now :P
Spotted a white M35, looked like aero kit on King Georges Rd at 11am right near AutoStyle, was dumped on black rims with copper brembos, really nice looking ride.
Then around 1:30 saw a yellow c34 on Sunnyholt rd Blacktown, near Vardys Rd.
Saw a black M35, most likely an AXIS, on the M2 Motorway heading south-west between the Pennant Hills Road and Windsor Road exits, roughly 5.45pm last night. I was heading in the other direction and about to get off the M2 at Pennant Hills Road.
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
