Spotted an arx (silver) on nicklin way between kawana and maroochydore (sunshine coast) about 6.30 p.m. last night (Thurs).. last 3 numbers of rego "310".couldn.t catch it through the traffic.Looked quite standard wih a set of aftermarket mags 17". Did look quite high at the rear.
    • Holy hell! That is absolutely stunning! Great work!!!
