Could possible be this one
http://www.carsales.com.au/private/details/Nissan-Stagea-2003/SSE-AD-415562/?Cr=12&sdmvc=1
Its been for sale for 5 months that I know of.
That car needs more low, and blacker trim. And black wheels before it'd look good, IMO.
Spotted Gav in his yellow C34 s2 on Old Windsor Road in Seven Hills this afternoon, then Dave (I think???) at the very last moment in his NM35 AXIS about 10mins later as I was waiting to tun into my street.
Hey Nick, yeah that was me, your car was looking schmick as!
I've spotted Gav a couple times goin down Abbott rd in the arvo, while I'm standing out the front of work and I usually hear you coming before I see the car :)
Spotted a Stagea mini meet in the Macca's carpark at Croydon this afternoon.
Well actually it was just 2 Stagea's. But pretty rare to see more than one in the same location! :P
Can tell you , there are two in my driveway...Mine and the son's.... another less than 250 meters... and the forth just two streets away. Here in Springwood they are as widespread as GMH Commandoors
Not sure if you meant us, but that was me in my dark green S1, Brendan in his pearl white s2, and eventually Laurence in his black s1 meeting up for a quick chat and exchange of parts at the BP/McDonalds on Parramatta Rd in Five Dock on Friday arvo.
I also spotted a silver s1 driving through behind the servo on R33/S14 wheels, and only just now(!) made the connection that it could have been Shaun.
Adelaide.. about 1.30 this arvo on eyre st. Seaview downs. Silver s2 heading up the hill. I was driving down :) dont know if iys just cos im driving a stag now bit ive been seeing heaps of them lately lol
Edited by staglover
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
