Last few days, saw a Red S2 C34 at Southbound F3/M1 McDonalds, White M35 Pacific Hywy Turramurra on saturday night and a Black S2 C34 heading south on the F3/M1 Saturday about 4:30pm (gave a thumbs up, got two thumbs up back! haha) If you're on here, I couldn't go over 80km/h due to running on a space saver rear left :/
My sister said she spotted a black Stagea (she said it was the newer one, so I'm guessing M35) on the M4 heading westbound cruising with a (white?) Skyline approx. 6.16pm tonight, the Stagea had rego STA634.
Spotted three today, first one was a white or silver s2 C34 heading southbound on Liverpool Road in Ashfield, then a blue M35 about 45mins later heading in the same direction, then another white s2 C34 (this time with a black bonnet) in Enmore.
Spotted a nice Blue RS4 on Old Cleveland Rd, Brisbane. Driver gave me a thumbs up (white 260RS). Very clean looking car with some nice wheels. I love the sticker on the back that says "my groceries are faster than yours". My Mrs commented on how clean the car was.
Have seen more and more stagea's around Canberra.
a really nice red 260? heading south onto northbourne avenue. and a nice stock silver nm35 heading down the parkes way towards Tuggers.
Also another silver nm34 with black wheels heading out of Bruce onto Ginnendera drive.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
