I spotted a red i think was series 1 with red number plates that somehow spelt stagea. in milperra on the m5 bridge
haha i have the same car.. but in perth.
red S1 with STAGEA plates.
when i tried to get a REVS check on my car in WA the lady kept saying it was under finance, but it wasnt. it was the damn one over there but she didnt tell me that!
Shaun
Spotted a light green series 1 with gold moulds on Rooks rd Nunawading sitting outside Kamikaze motors,Cood have sworn i saw that car 4 sale in that same showroom two weeks earlier, hmmm duno bout the gold moulds :laugh:
Spotted a Yellow Series two on the Pacific Hwy near the Great Northern Hotel.
I was going the other way and waved, but i dont think they saw me.
Its the first Stagea I have seen on the road since getting mine.
Ben.
That could well be Andrew "wolverine" or his wife. Did you get a chance to see if it was an RS Four S?
I spotted a nice black beauty on the road between childers and Bundy! I think it was a series 2, bit hard to say, it was all but past me before i noticed!
MAn I'm slow sometimes!
That was on Sunday the 25 feb.
spotted a series 1 with chrome rims this morning turning onto armidale road had a forsale sign on it and he waved back when i waved.
also have seen radiums car every morning last week on mounts bay road.
also spotted a white series 2 stagea with r34 gtt rims at bp in thompsons lake tonight about 7pm was nobody in it
Spotted a silver s1 Stagea heading into the complex where Unique Autosports used to be in Castle Hill, around 5.30pm tonight... Looked to have standard wheels, so it wasn't "PranK" Christian's old car - his has s2 taillights on it anyway...
i saw a wicked Silver S1 on smith street down the gold coast.. came out of an on ramp 2 cars in front of me i was on the fone hung up and chased him got side by side giving him the thumbs up then pulled slightly ahead to check out the front of it. it had a nice front mount on it with a full Dayz kit all the way around {mine has a dayz kit minus the front bar extender} it was an auto aswell cause he upped it and i could hear it kick back and it sorta did the exact sae thing mine did...
lol now thats a long post.. must be the boredom and insomnia kicking in :O
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
