October SAU NSW Monthly Dinner - Thursday 28th October - STEAK!1!1!1!
  • Replies 117
Ok, looks like i'll be able to pop down as well - Is there anyone coming I can throw a SAU form & money at?
I can take the membership from you Zebbie :D
This is a special night as Carlo is doing a free lap dance for anyone who joins at the dinner. :uh-huh:
yeah.. I just need to come over and borrow your latex marilyn monroe outfit. Oh and did you fine the stick on mole after that last party??
Taking a break from it this time round Dino?
i see the new wheels are attached. are they as full sick as you predicted?
Richard
HAHAHA gp have Steak in Wullington Dundan :D
:devfu: they don't have steak here only lamb and mutton....for some reason they only seem to have sheep :confused:
how odd :confused:
you don't get the good export quality beef we don't get to eat?? :D
It's all in Japan mate!
And yeah duncan, your non-attendance has been noted :)
Also for the 1/11 trackday. tut tut.
Blitz:
huh? what? wheels? where? me? don't know what you mean...
Well, the steak is really an excuse to strech the legs on the 'line ;-)
I'll prob come down early and have a scout about for a motel, as there doesn't seem to be much online for Chat's West :-/
/me goes and finds a pub with a pool table
maybe check out north ryde instead, I think there are a few options there and you wont have to pay //orthside prices http://www.yellowpages.com.au/search/postC...+ryde&stateId=1
And enjoy the drive :P
Well there is actually a hotel on the same street (Delhi Road) as the steak joint.
It's pretty damn close in fact, it's also brand new and fairly fancy looking so the price might be up there somewhere. It's called "Somerset North Ryde"
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
