October SAU NSW Monthly Dinner - Thursday 28th October - STEAK!1!1!1!
  • Replies 117
There are also heaps of hotels/motor inns along the pacfic highway between chatswood and st leonards the furtherst of which would only be 5 mins from the steak-a-thon. Artarmon motor inn is one that springs to mind. Should be around $60 for the night too.
Richard
w00t teh ceffy just got dropped off at the auto elec for a R134A regas. Will be ready by 3pm says he. Then I'll probably cruise up to UAS to drop some stuff off to John (the CB radios).
So I'll be there with bells n whistles on for Carlo's lapdance.
Also are we having any pre-dinner meet n cruise thingys? I'll be family sedan sleeper dori-dori-ing from Dundas.
BTW I didn't bring any footwear other than a pair of open toe sandals (being my holiday n all). I'm guessing since its a steak house they won't really care... if not I might have to borrow some of my old man's daggy old man shoes.
I would not worry about the shoes dude.. We could probably rock up in speedos and apart from being all a little weird and uncomfortable have no issues in getting a decent feed.
I picked up my g-string and hot wax.. so im ready for tonight.
Funnily enough I'm suddenly not sure I'm coming tonight...
I wont steal your thunder richard, you can still show everyone your new trick. I too am curious how you do it
orright, but I warning you all. Bring a pack of baby wipes to clean up with...
:uh-huh:
oh and I'll bring some R32/R33/R34 catalogues which made their way up with me from Melb so you guys can check em out if you want.
But you already booked yourself in for the back sack and crack with Carlos Beautician service Richard - cant very well pull out now, that would be very uncooth.
Carlos Beutician Service hey... why do I keep picturing a devious, hairy man with a huge strip of sandpaper and some tweezers?
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
