And its a manual Aussie Toyota Sprinter (AE86).
Cost me peanuts (was supposed to be $450, but the seller kept gettin calls from people offering more for it so it went up in price) to buy. Its sittin at a mate's place in Nerang QLD atm. Trucking it down from QLD to VIC, where I'll start restoring it.
Its a sack of shit, drives OK, rust everywhere. Interior's f**ked. Instrument cluster dosen't work, tyres are balder than a stripper's crotch.
Will be repainting it and hopefully can get a Trueno frontend (guards, CF bonnet, light assembly) from japan, along with some Tanabe's. Probably a MR2 engine or something (haven't decided yet) maybe even an SR20 or CA18. I also have a spare RB20DE engine but I don't think it'll fit nor be any good for the weight distribution.
Haven't decided if I'll be using it as an all out drifter or an Initial D replica. Either way it'll have Fujiwara Tofu Shop on it :D
https://www.sau.com.au/forums/topic/53506-w00t-just-bought-a-project-car/
lol I'll have to restore the car first before I go putting mods in... all that rust that needs to come out and a nice fresh lick of paint... interior retrim...
I need to find a spec list of a AE86 GTV or whatever the top of the range one in Japan was and and AU AE86 and make up a list of upgrade parts to go shopping for.
Teh Hachiroku cannot loose on teh mountain!
Now... should I:
a) Replica it and then park it in front of the cinemas when the initial D movie comes out and put a big for sale sign on it :D
B) drift its tits off
yeah that's the probloem I'm facing, most engines are E-W. I'm leaning towards a 4AGZE engine from a supercharged MR2. Failing that a 3SGTE off a celica with a TD06 or something.
yeah I know they're all E-W, I'll have to modify em to fit...
or i could be slightly different and fit an FJ20DET into it ;)
Dude, now your talking nonsense, why bother making things difficult for yourself.
A 4AG with Grp A internals will rev out to 11000rpm...that already will give you plenty of fun.
too much Initial D for you... besides... Grp A internals aren't cheap. Supercharged MR2's are pretty common these days, so finding the engine out of one shouldn't be too hard.
Ronin... Fujiwara Tofu Shop is what's written on the side of the AE86 owned by Takumi in Initial D.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
