Hello.
I just got my Stagea last week and I'm rapt with it. I've put a turbo back 3" exhaust on, an Apexi Power Intake and a GFB BOV. I just installed an RSM today.
I have a weird problem. It seems that when I put the foot down and then come to a complete stop the engine will die. It happened twice today when I pulled out of a carpark put the foot down to go up a hill then stop at the top for a roundabout. It's an auto. Has anyone else experienced this? Why is it so? My car has only done 34000ks.
Please help.
Thanks.
Zane.
https://www.sau.com.au/forums/topic/53534-help-my-stagey-stalls/
Hi Zane, you can't have a open to atmosphere BOV. The ECU knows how much air goes into the engine via the AFM, so it squirts in the right amount of fuel for that air. But the BOV lets a whole pile of that air escape, so the ECU squirts in too much fuel when the BOV is open. Bingo, too rich a mixture and the engine stalls. Get a plumb back BOV and all will be well again. I have never found anything wrong with the standard BOV, so I have and will not be changing it on my Stagea.
Hope that helps:cheers:
My BOV is a Hybrid valve. If I turn it further towards plumb back this should fix it aswell?
Also the other day when it stalled I put it into P so I could start it again but my car was still rolling a bit. It started making this shocking noise. Kinda like when you do your diff. I stopped and put it back into D and it went O.K. Would I have done any major damage? Feckin' hope not.
I had a feeling that may have been what it was. If I buy an SAFC-2 that should fix my problems yeah?
Thanks for the help
Nope, the SAFC has no ability to adjust zero throttle richness.:P
Yep around 60% or more plumb back will help, assuming it is physically plumbed back of couse.
Oooops, auto gearboxes have a lock on the output shaft so that when you put them into Park the car doesn't roll. Hopefully you didn't break off the locking pin. Easy to check, just put it in Park on hill, when you are stopped of course, and make sure it doesn't roll.
When moving, Neutral is the place to restart the engine.
Thanks for your help mate. My mechanic just told me the same thing. I have just had a boost gauge installed. I noticed that boost is around 5psi then goes up to 10psi at around 4500 revs for a little while then it drops back to 5psi until redline. Is this normal?
I think the SAFC II model has the feature to adjust the fuelling mix as it returns to idle. This is to stop the overfueling that happens and stablize the idle. The earlier editions didn't have this feature. It must have been a feature added purely for the addition of externally venting BOV's.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
