ive brought a new tacho and its not auto meter but the old one is when i cut the old one and put gree2green black2black red2red on the new one i noticed the white wire in the dash and so does the auto meter gauge have white wire does any1 know where this white wire should go (all the wires on the new 1 are hooked up it has red, green,black,2 4 the shift light also do i turn the headlights on or just accessories (the auto meter i had hook up by an auto elec) done same gauges on diffrent cars but they all had white
https://www.sau.com.au/forums/topic/53556-monster-tacho-help/
why do i have 2 put it on the bonnet when the autometer tacho was mounted inside and i was trying to use those wires and cant see why i cant ---- as 4 the lights inside the tacho they are working when red,black, green are hooked up even with the white not conected the lights work but the rpm is not reading which wire reads the rpm - on the tacho
(THE NEW TACHO DOSENT HAVE WHITE )the wires comming out of the dash were for auto meter - (white) red green black - BUT THE NEW 1 DOSENT please if u dont know why the white wire is on the old tacho and not the new thankx but no thankxps the lights work 4 the tacho ---- when do i turn acess on - think ill spend the $50 - thought sum guys in here could help ---hhhhhhhhh
with your headlights off try using a test light on the white wire from the dash see if your test light comes on if it dosent then turn your lights on and see if your test light comes on if it does then you know what that wire is for now with the green wire (tacho signal wire) with your car running hold your test light on the green wire coming from your dash if its getting a signal your tacho in your dash should drop to 0 revs hope this helps you
if the white wire has power when you turn your lights on just tape it up as your new tacho must light up when eva your car is on when i installed my tacho i didnt disconnect the battery or have the ignition on all i did was wire it up with my test light it was all good goodluck
NEW PROB the white wire is for the dash and boost gauge and if i connect it to red i have boost and dash lights (hmmm even with the headlights off -wtf) if i just tape it up i have no dash and boost lights as 4 the tacho u can turn it of at the tacho -so i think it must run all the time 4 sum reason i think i cant have this tacho
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
