Genuine Nippon Denso intank fuel pump kit
280 litres / hour - 110 psi
http://cgi.ebay.com.au/ws/eBayISAPI...item=2493874720
i just get a fuel pump from ebay...can anyone give me a guide how to change it? Better with some pics...hehe...And where can i get the fuel pump filter in Hobart? Is there any thread that guide ppl to undo the dashboard out with pic for manual R33 GTST? I'm going to spray the dash...coz all the rubber drop off......And anyone can tell me where can i get a cheaper alarm and immobilizer installation in Hobart?
i just install a bleed valve to get 0.8bar....the guy told me premium unleaded fuel....only can get up to .8bar...more than will damage ur engine...is not good...and i have blitz POD filter and 3inch turbo back exhaust..next week will change the dump and front pipe and cat to 3inches...then follow by FMIC....
Just wonder like these modi....is apexi SAFC II suit or power FC better? I'm not going to change the turbo...will be using stock turbo...can AVC-R set my fuel map(like SAFC)?
Can i know where is Baskerville or Symmons circuit locate at?
https://www.sau.com.au/forums/topic/53572-some-ques/
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
