  • Replies 123
On a serious note, the standard setup of a GTR is so far ahead of the R33 GTS25t (as original cost would attest) that any advantage in weight is overcome. I'm yet to try my 25t on decent suspension but I have an expectation it will improve the result dramatically. With unmatched std shocks and harder springs it takes a delicate touch. The GTR track is wider as well and influences handling a huge amount.
Too much power in the GTS makes it too hard to go fast at PI and as Andrew said, you can maintain commitment in the GTR. For knore, I was running 220rwkw at 15psi and managed 2:03 on road rubber, then dropped to 11psi and went 2:00.6 so getting the power down becomes a problem out of a few critical corners. Sandown is one with tightish corners onto long straights so again the GTR will rule. We can't include Ben's GTR as an example due to the mods (is there a trach GTS with that much done to it? mine will take a while:D)but certainly Scotsman (chris) is a real demonstration of what a pretty stock GTR can do. Take the 5 seconds a lap out for cheater rubber at PI and he is then 3-4 seconds faster than me.
The R34 is undoubtedly an improvement again over the 33 in both models seeing the handling of Adz's car compared to mine. We were pretty well on par but I had roll bars. While I never got enough track time to be consistent I have put together individual laps earlier in my racing life to be on par with some of the top five to ten in my races in u2L sports sedans, clubman karts and F Ford (which was an awesome demonstrator for driver ability in equal equipment).
mostly though driver ability and commitment are the biggest influencing factors.....and I suck. I'd rather drive it home.
On a serious note, the standard setup of a GTR is so far ahead of the R33 GTS25t ....  .
:werd:
The way i see it they have bigger rotors, stiffer bodies and susp, better diffs, good intercooler, way more power with just an exhaust, boost increase and tune, slightly wider track and larger diameter and also wider rubber on all corners!
About the only fair comparison is skylinegeoffs R33 GTST vs Scotsmans GTR. But he cheats and uses sticky rubber.
Dont really agree with that. Your car needs decent tyres and susp upgrade and a good alignment. How much more traction did you have with the stickies...then consider shocks/springs and a decent alignment. A well sorted GTST can handle way more then 220rwkws...i was making 206rwkws at PI and the thing was hooking up nicely:) (The few corners it ran properly:()
Biggest variable is driver and tyres...only have to look at Duncan/Fatz lap times in a std R33 with sticky rubber if you want to feel inadequate:(
Hey snowman, bout your theory, I have tried and tested, and it has to do with the g sensors for the awd in gtr's. depending on where u are it can change dramaticaly. Phillip Island and in general, further north changes the effect of the lateral sensors, which in turn brings the front into play alot faster when exiting corners, further south, the opposite will happen. The best mod I have done to my gts-4 was to rotate the lateral g sensor 90 degrees, the result, fantastic handling, now i can exit corners and not have to worry bout losing it.
Gimme some cheater tyres and lets talk about small ballz. Until then...  :talk2hand
Your R32 already runs bigger wider 17s with the 4wd, thats enough cheating for you my friend:)
I seem to recall that you ran Race Brakes Comp 9s, what did you think of them? Im about to throw a set at my car, but i seem to recall that they kinda ate your rotors:( Perhaps i shoudl just throw them in the night before a day at the track?!?!?!
I was hoping to see how the GTST went up against the GTRs on the weekend, but my car was sabotaged by Snowmans mechanic to stop me from beating him:)
Disclaimer: if my car is as quick as any GTR with less then 240rwkws then i see that as a win:)
I've been having a think about this and I reckon the only things I could think of were when us RWD drivers break traction coming out of a corner we have to ride it out or back off, both will slow us down BUT when a 4WD breaks traction coming out of a corner all you do is point the car and floor it and the torque splitter does the rest, thats enough cheating in my opinion.
Oh another funny ones is when you have a GTR driver in the passenger seat and they say "break later, break later". The GTS-T and GTT breaks sure don't hold up like the GTR's. Any later and my car would be a smear on the wall, well an even bigger one than it is :P
Having 4WD does not compensate enough for having semi slicks. The cornering G's of 4WD are nowhere near RWD with slicks! Lets not forget how much later you can brake.
Comp 9's were REALLY good but they demolished my standard rotors. The DBA's seem to take it a lil better. Noisy though. But yeah, better as a track only option.
...The GTS-T and GTT breaks sure don't hold up like the GTR's. Any later and my car would be a smear on the wall, well an even bigger one than it is :P
LOL...that aint funny:(
But normally those same GTR drivers run sticky rubber and have susp work. It makes the car so much more stable and allows more confidence when braking. I dont think Scotsman use to brake as late as Snowman, and i dont think it has so much to do with R33 vs R34 or driver ability as it did tight susp vs sloppy std stuff.;)
They were dead even yesterday now that they have basically the same mods. On paper Scotsmans brakes are as good as Snowmans for about 2-3 laps, then the aluminium hats and better cooling of Snowmans should mean his resist fade better.
But GTRs do come with the good stuff factory, while us GTST owners have to hunt around part stores to retro fit the good bits to our cars:(
In a GTR when the ATTESSA kicks in does it upset the line of the car much. I know in slow corners when it kicks in the things start to understeer (Turn 2 and 9 at Easter Creek) On the quick stuff though can you keep yor foot planted and hold your line?!?!?!
I think so much advantage of the GTR comes back to the RB26 and great chassis, it has less to do with the 4wd. Oh and show me a GTST with 17" 255 rubber all round:)
If we were doing 35 laps and needed to look after our tyres then yes the GTR would come into its own. For the sake of a few laps around the track i dont think the 4wd (especially the way ATTESSA is set up from the factory) there is much advantage...
Having 4WD does not compensate enough for having semi slicks. The cornering G's of 4WD are nowhere near RWD with slicks! Lets not forget how much later you can brake..
Thats the line im towing and im sticking with it:) Traction may be similar, but braking and lateral grip woudlnt compare (well at least thats what i think)
absolutely. rwd with semis > 4wd with road tyres. any day.
Adzmax, are you running semis as well? they make a hge difference to braking, much more than the size of the calipers or discs.
I've found my brakes work a treat. Gtst's fading while I keep up the laps.
Never had any fade at all.
I guess I'm not going fast enough hehe.
Driving like a girly girl racer your right, I don't experience any brake fade but when I decide to step up and really push it I'm breaking a hell of a lot later and harder, thats when brakes start to crack the poo's.
I was running street's last weekend and your right, that has a hell of a lot to do with it.
One thing though, are you trying to tell me that a GTS-T/GT-T with semi's can go round corners as quick as a GTR with semi's?
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
