Just thought of the reason why NSW GTRs are so much slower. You see its to do with SBS:) (Its been a while since GTR owners have had a panic attack over SBS….muahahahaha)
We don't watch SBS much. ;)
I'm off to Traralgon Sat for the night so have to ring Emre to see if he's on for a barbie.
Give me a holler mate.
  • Replies 123
Duncan...you and i both know the GTST is better for the track.
Let the GTR drivers keep their pride in check. They don’t need us rubbing their noses in it. After all how, think how we would feel if our cars were twin turbo and 4wd and yet slower then a single turbo RWD car, bit like us getting done by a Type R Integra me thinks:)
Im not sure if there have been any Skylines in the Vic or National Improved Prod Championship rounds at PI. I seem to recall that about 1:46s is close to the top of the food chain in the Vic State Championship (Little old Series 1-3 RX7
VITZ,
The 1.16 GTR is pumping out.... plenty. But it's the response, handling and stopping that makes that car the weapon it is - not just the horses.
The S15's I personally think can be a fantastic track car. For a point of reference go and see Donald down at Evolution R for a perfect track S15. He's done a 1.22 around Sandown in his with only around 220rwkw's - but like the racepace gtr has been set-up for response, handling and stopping.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
