Dont know if anyone can help, but supposing you had 18x10in wheels on the rear and 18x8in wheels on the front of your R33 GTST, would it be illegal?
From the RTA website I believe you can increase the width and diameter by 1in over standard.
My question is, is the standard taken from the model, or series etc? ie is the standard taken from the largest factory wheel size for skylines in general or just GTSTs?
I think Skyline GTRs came with 17x9in from the factory does that cover skyline GTSTs as well?
Im thinking it would be specific to each series of skyline, can anyone confirm this?
Thanks!
https://www.sau.com.au/forums/topic/53580-wheel-legalities-in-nsw/
but I'm pretty sure there is no rule in NSW regarding rim height. You can go 1" wider than what it says on your tyre placard...and skylines have different placards depending on the scheme they were imported under and even different companies that complied them
you are right duncan you can have 20" rims if you like as long as the wheel tyre diameter combo is the same as stock ( they allow about 3% either way i think ) .
as for the width you can only widen the wheels by 1" but the track can only be 1" wider , but who is going to check the track width ?
nah its much easier for the cops.....they just see big wheels and go "bingo! Youve got a defect" See they don't have to be right, they just need "suspicion" that something is wrong....in fact I've even heard of cases where they have been shown the engineers certificate saying it is legal but still defecting the car anyway....
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
