  • 4 weeks later...
You can put a R34 GT-R speedo cluster into a GT-t but it requires a re-wire of the plugs as the connectors on the back of the cluster are on opposite sides and the warning indicators are in different locations. The short of it is.....It's not a direct swap. The car will not run if you plug a GT-R speedo cluster directly into a GT-t.
I am planning on doing up a patch cable assy to use so I don't have to butcher my stock wiring harness. (I have a GT-t)
An alternative would be the NISMO 300km/h cluster for the GT-t, pricey though.
https://www.sau.com.au/forums/topic/53586-r34-speedos/#findComment-1080830
