hi there fellas,
im getting a front mount soon for the line and more than likely be installing it myself. Ive looked at the one currently on my silvia to get an idea of how to do it but I would like to know if any one here has installed one themselves and if so was it easy or hard. More importantly though is would anyone be willing to give me a hand - there are incentives. :cuddle: Im not sure if all front bars are the same but i have a series 2 and it looks quite time consuming. btw the cooler is a 600x300x76 variant.
cheers,
dooky.
https://www.sau.com.au/forums/topic/53592-intercooler-install-help/
  • Replies 47
I have a hybrid cooler on my 32 that is the same size as yours. me and my friend put it on. It wasnt hard just abit time consuming. I have a gtr front bar that needed some gentle moulding with a angle grinder :P to make it all fit.
Make sure you line it all up properly and it all square before you cut the hole in the engine bay for the cooler piping.
cheers jagar. Apparently there is not alot of piping need as you may think - i was thinking the same in the beginning as well. I dont have a pic of what it will look like but if you have seen a thread going around by wados then that is what mine will hopefully look it.
personally i don't like the 180 trun around in air flow as i just cut a hole under neath the relay box bit more heat but then i ot ss piping, an exhaust shop can do it for like a 300 bux, but then that mild steel which doesn't conduct heat very well and no clamps and stuff included.
evan usually does ss and high tension clamp and hose, the best sh1t around, have a chat to him cool bloke tells you as is no sh1t involved
i had a chat to evan, yeah his prices were quite impressive and sounded like a nice bloke. Although when i headed now to an exhaust shop which to my suprise quoted an even more impressive price - quotes were in stainless steel btw. this certain shop wanted $170 for the pipes that i was after then asked if i was going to weld it myself - i think the guy thought i was welding an exhaust system as i didnt tell him i wanted it for intercooler piping. on this note, would welding the pipes were the bends are be much better than clamping them together with silicion hose.
Ive taken that issue into consideration but dont have any other alternative to go with atm. fabricated piping - the one in which goes over the engine bay cost approx. $600 while this is only a fraction of the price. Another problem i have is that if i wanted to use less piping ie over engine bay again, there is no measurements which i can go by unless someone here can give me theirs or can the workshop do this for me as when i asked i was being specific.
have you finished your masters yet. on another note, i was advised to get a compression test done before i install the cooler. Is this true or would i just be asking my money - either way it doesnt make sense to be in having a compression test done just for the sake of adding a mod. any ideas??
the pressure drop over that much piping would be insane Duc .... lag city I reckon!
if you calculate the total length of the piping going back to the factory locations it works out about the same as the more common across the engine setup.
I have done the aforemention install and have no noticable increase in lag.
sweet. Did you by any chance use the piping measurements that wados used on his 32 or was your already made to measure. If it was custom, could you please tell me your measurements as i dont want either excess or shortage of piping when i come to install the cooler.
edit - i just had a look at your gallery and noticed that you also had a series 2 front bar. I was wondering if you had to make alterations to it for the cooler to fit.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
