Sime Posted October 15, 2004 Share Posted October 15, 2004 Hi everyone I originally had a standard BOV on my R33 which had been welded up to give that flutter sound, so I went and bought another standard one thinking it would be nice and quiet but found it makes the typical pshhh noise I'd expect from an aftermarket one. Is this normal? I'm running 12psi of boost so perhaps that causes it to be make more noise. I've also checked to make sure all hoses are secure and not leaking. Also when I took the old one off, there was a metal plate in between the BOV and the air intake pipe it attaches to. This has a hole in it smaller than the opening on the BOV and causes a slight flutter noise and a slight pshhh. Is this supposed to be there or did the previous owner put it there, perhaps to run higher boost than the standard BOV can cope with? Link to comment https://www.sau.com.au/forums/topic/53613-standard-bov/ Share on other sites More sharing options...
krzysiu Posted October 15, 2004 Share Posted October 15, 2004 My standard Blow Off Vavle copes with 17Psi. Are you sure that the plumb back pipe is connected? Link to comment https://www.sau.com.au/forums/topic/53613-standard-bov/#findComment-1051863 Share on other sites More sharing options...
Sime Posted October 15, 2004 Author Share Posted October 15, 2004 My standard Blow Off Vavle copes with 17Psi. Are you sure that the plumb back pipe is connected? It's definately connected, I take it it's not supposed to make much noise Link to comment https://www.sau.com.au/forums/topic/53613-standard-bov/#findComment-1051876 Share on other sites More sharing options...
2BNVS Posted October 15, 2004 Share Posted October 15, 2004 mine made a fair noise, not as loud as my new gfb hybrid, but with the pod filter it could be easitly heard and once the fmic was on it started fluttering too ben... Link to comment https://www.sau.com.au/forums/topic/53613-standard-bov/#findComment-1051936 Share on other sites More sharing options...
Sime Posted October 15, 2004 Author Share Posted October 15, 2004 mine made a fair noise, not as loud as my new gfb hybrid, but with the pod filter it could be easitly heard and once the fmic was on it started fluttering tooben... Ahhh! I have a pod filter also so that maybe why. What about the metal plate. Is that supposed to be there? Link to comment https://www.sau.com.au/forums/topic/53613-standard-bov/#findComment-1051951 Share on other sites More sharing options...
drewecrome Posted October 15, 2004 Share Posted October 15, 2004 hey mate, i just changed my BOV, that metal plate is a gasket. And as said above the swoosh that u are hearing is your pod, if you had your old air box put back in you would hear nothing. Link to comment https://www.sau.com.au/forums/topic/53613-standard-bov/#findComment-1051966 Share on other sites More sharing options...
Sime Posted October 15, 2004 Author Share Posted October 15, 2004 Thanks guys Link to comment https://www.sau.com.au/forums/topic/53613-standard-bov/#findComment-1052069 Share on other sites More sharing options...
2BNVS Posted October 15, 2004 Share Posted October 15, 2004 when i changed the bov, that metal plate was like an adapter plate thats bout it, and yeh like said u wouldnt hear anything with ur old air box, the pods are quite loud especially hks ones cheers...ben. Link to comment https://www.sau.com.au/forums/topic/53613-standard-bov/#findComment-1052807 Share on other sites More sharing options...
