Well, the changes should probably make for a somewhat more interesting competition next year, which is what they need.
They had to do something, they were losing viewers and sponsers in droves!
The changes to rules about team orders, testing on friday before the race and tyres are defnitely good ideas, will make for better racing and should benefit the smaller teams.
I'm undecided about the changes to the points system and qualifying - I think we may just have to wait this one out and see how good or bad it is.
Removing Spa from the calender is a BAD idea. It's one of the best races, always interesting and more overtaking than anywhere else.
Changes posted below:
Qualifying
- There will be two qualifying sessions - Friday and Saturday, both 13.00 - 14.00;
- qualifying to be one (only) flying lap for each car, cars to run one at a time;
- running order on Friday to follow Championship (previous year at first race), with Championship leader going out first, 2nd in Championship running second, and so on;
- running order on Saturday will be determined by the Friday times (which do not count for the grid), so that the fastest on Friday runs last on Saturday, the second fastest second last, and so on.
Practice schedule
This will remain Friday: 11.00 to 12.00 and Saturday: 09.00 to 09.45 and 10.15 to 11.00 (with qualifying from 13.00 to 14.00 both days, as above).
Testing
Provided that by 15 December, at least three teams undertake to the FIA not to run more than 10 car-days of private testing between 1 March and 1 November, the teams which have given this undertaking will be able to test at each Event from 09.00 to 11.00 on Friday and may use their spare car and their test driver during this period.
World Championship points
From 2003 points will be awarded down to 8th place on the scale 10:8:6:5:4:3:2:1 - (previously to 6th place on the scale 10:6:4:3:2:1).
Team orders
Team orders which interfere with the race result are prohibited.
The 2003 Belgian Grand Prix
In the absence of unanimous agreement by the teams to run at the 2003 Belgian Grand Prix without tobacco advertising, this event has been removed from the World Championship calendar.
Tyres
Each team will be allowed to use two different dry tyres at each Event, (previously each tyre company could supply only the same two dry tyres to each of its teams). Teams will continue to be limited to 10 sets of dry tyres per Event. Only one type of wet tyre to be used per Event.
https://www.sau.com.au/forums/topic/5364-new-changes-to-f1/#findComment-82109
Umm, I think the tobacco advertising was just the straw that broke the back. Bernie's trying to make room for more non-european rounds (shanghai, bahrain etc).
Don't know about the qualifying though - why don't they just draw lots like the Brutes. Seriously, you don't want the slow and fast cars mixed together on the grid. Perhaps Jag will be in front of Minardi for a change though:lol:
https://www.sau.com.au/forums/topic/5364-new-changes-to-f1/#findComment-82698
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
