  • Replies 202
Hey all, I have a heap of parts I am selling for a mate plus some of mine ... most of them are off a wrecked R33 SII ...
- Front Headlights - $250ea - will need a buff - DON'T WANT TO SEPARATE! - SOLD!!
- Front guards - $350ea
- Front Bumper - $100 (cut out for large intercooler)
- NISMO Strut Brace with master cylinder brace - $250 - SOLD!!
- SII RB25DET Motor/Box in EXCELLENT condition - $3500
- Full Interior minus front seats (I'm talking everything !! Dash, Door trims, Hood Lining, Parcel Tray !!!) - all in excellent condition except drivers side door. - $1800
- Blitz Turbo Timer - $100
- Cat Back Fujitsubo 3" Mild Steel Exhaust - $300
- HKS Pod Filter - $100 - SOLD!!
- Boot lid minus rear wing - $200 - SOLD!!
- Nissan Genuine Floor Mats - $150 - SOLD!!
- Damaged GREDDY Intercooler (Doesn't leak, looks bent - needs fixing) - $150
- Radiator $200
- SII Rear Strut Brace (Like GT-Rs have) - $200 - SOLD!!
- Air Bag Steering Wheel (Good condition) - $150 - SOLD!!
- Standard SII A/F Meter - $100 - SOLD!!
- Tail Shaft - $150
- SII Body (Needs Drivers side sill, rear quarters, Drivers door) - No glass - suit speedway/drag car NON ROLLING Silver - $3000
- Passenger side door complete with glass, motor for window, excellent condition - $600
- Front Windscreen - $250
- Rear Window - $250
- Side Quarters - $150ea
- Rear tail lights (Scratched lenses) - $50ea
- ApexI Multichecker - $250 - SOLD!!
- SAFC (Old Style) - $150 - SOLD!!
- Mines Modified ECU to suit SII Manual - $350
- Standard Manual ECU SII - $150
Pics will go up laterer today - all quality gear at low, low prices !! Get in quick - buyers to pay freight - pickup is free - I am in Central Queensland.
Maybe more parts as I go through my house :)
PLEASE DO NOT PM ME - PLEASE JUST POST IN THIS THREAD it's easier to reply and everyone can see what is happening this way.
PICS ARE HERE
What type is the bumper and what condition?
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
