hey guys
ive got an R32 GTS that i am doing a brake up grade to
ive got R32 and R33 GTR disc, caliper and hub
i want to use the brembos off the R33 i have DBA discs for em already but which hubs can i useR32 GTR or R33 GTR? will either of em fit on the GTS?
or will i have to go for GTSt ones???
any help is much appreciated
thanks
anf
https://www.sau.com.au/forums/topic/53672-r32-brake-upgrade-please-help/
hey guys
thanks
anf
Use the disk and calliper off the same model and they will bolt up no problems;:D
so R32 GTR discs and calipers will bolt straight up to a GTS-t? no custom caliper brackets etc needing to be made?
The R32 GTST M Spec upright has the calliper bolts in the same place as the R32 GTR upright. The R32 GTR calliper has longer "ears" to fit the larger diameter rotor. By the time you have typed the question you could have fitted up one set of brakes, just get into it:cheers:
