Quote: "RB30 (japanese Spec) carillo h beam robs,"
There was no RB30 in Japan????? Except the Kaira M30 which was a stroked/bored RB20.
youre absolutely right there was no rb3o in japan BUT the Rb30 skyline 89' model was cast in japan hence (japanese spec)its not a holden block.
  • 1 month later...
  • Replies 50
None of them are Holden blocks.
The "Holden" blocks were all made by Nissan.
(They all have the Nissan emblem cast into them) :D
What bodykit is that on ur car? it looks mad!
wat front bar, side skirts n rear bar is it? n how much did it cost u all up?
Looks like one of those tragic Team JetSpeed kits.
                   387rwkw from an Apexi AX53B70 is pretty good going, considering they rate the turbo at 380ps...
That dyno run was performed at 1.7 bar and the turbo was running out of steam.(started surging).I might be lookin for an rx6 soon!
                   according to my dodgy little chart thing:
 AX53B70 P21 = ~320ps
 Ax53B70 P28 = 650ps and ~690ps
yep i got the p28 ax53b70 , good work.
Then why was it running out of steam?
mine produced 214.8rwkw
my DYNO sheet reads 284.8rwkw  ....
Hi ya guys I t has taken me two years..blah blah blah...
producing a lazy 386.7 rwkw
hahaha
Pick a number and stick to it :D
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
