  • Replies 50
Hi ya guys I t has taken me two years to get here and here it is, apexi power fc, apexi ax53b70 turbo, apexi induction kit, blitz lm spec intercooler, nismo fuel reg, nismo fuel pump, nismo injectors, nismo short shifter, nismo gear knob, trust oil cooler ,4 ' turbo back dump and exhaust(apexi), RB30 (japanese Spec) carillo h beam robs, ross pistons forged, total seal rings, balanced and blueprinted crank, n1 water [pump), n1 oil pump, ks cams, tomei valve springs, tomei valve guides port and polished heads, producing a lazy 386.7 rwkw? Im going porsche and ferrari hunting today!!!!!
This is a funny post!
Bahhaha prank this should be in the wasteland/jokes section.
A true engine performance upgrade...
because everyone knows the RWKW performance gains of the %10 shorter than factory shifter & overpriced plastic gearknob!
Also i love your blueprinted crank!, but i dont know of many engine builders that will bother to blueprint just a specific engine compent such as just a crank or just rods or just rings (because that not blueprinting mate) blue printing is painstakeingly going over EVERY bearing/sleeve/ring/gaps etc. And perhapes buying 9-10 packs of rings & bearings and makeing sure all of them arel within +/- .001" of each other also + maybey $2-3K ontop of your engine build ... maybe you should understand what blueprinting means first and how REALLY BLODDY expensive it is to have done properly. (Ive included what it actualy means below, so next time you dribble rubbish on another forum they might just believe you? :kick: )
WHAT IS BLUEPRINTING?
Contrary to its name, blueprinting an engine has nothing to do with big rolls of paper that have strange, blue-colored drawings on them. Blueprinting an engine starts by designing it on paper first. Calculating things like compression ratio, piston pin (compression) height, displacement, and carburetor cfm requirements are all the beginnings of the true blueprinting process. From there it involves properly communicating your needs to the parts manufacturers and to your machinist and finally checking the parts, by hand, to ensure that they all meet your requirements.
Take a read, learn what you think your motor has, and stop dribbling dude.
:D
I think he delete a thread he post in SA section a while ago, tell everyone he own a 1000hp R34 Gtt and with a lot of mod
and he won't show us the car, cos he is not that "stupid" to drive it on the street and let cop defect him...
these aussie plates?
Yeah they are Aussie plates..squint a bit and you can see "SA" on the left
Those style plates were an option if you had 7 characters in SA I think?
@ Original poster: SHOT DOWN!
There is another thread started by the same user which I've already moved into the wasteland.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=58496
:headspin:
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
